P2075 Fault Code
Intake Manf Tuning Valve Position Sensor/Switch Circuit
I have searched this on the forum and not found a definitive answer, the code I'm getting is it related to the throttle body or is it to do with the secondary air intake off the air box that operates via vacuum and the little solenoid that is attached to that.
I have recently purchased the car, so trying to iron out the problems. It came with an installed cone filter which I immediately removed and re-installed the OEM air box. Is the solenoid powered by a fuse at all that could have blow/ taken out?
Thanks for any help. Cheers.
