ex Nimbus r27r #2054
Yesterday i fitted the camber and alignment shim
Camber is ok (around 2degrees) maybe i'll try another 20'..
The alignment is a little close yet... I'll add another shims.. We want to have a 10' open for side..
Anyone has the standard rear alignment data?
For the rear?
I got those from here somewhere mate.
Rear Toe Settings
-0.52degrees with a tolerance of +-0.5degrees which means the acceptable Toe range
-0.02 and -1.02.
Rear Camber Settings
-1.55degrees with a tolerance of +-0.33degrees which means the acceptable Camber range is:
-1.22 and -1.88
Hope that helps mate
Rear Toe Settings
-0.02 and -1.02.
-1.22 and -1.88
-0,2 and -1,02 is too much difference.... :worried:
from neutral to 8mm close.......
I see.
How you doing it?
Sanding down the metal, then primer, then sand it down again, primer it, sand it down, spray it black, sand it, paint it etc?
Rene i watch in rc... @monza there are no 100-200kmh in straight..
I've a 100/180kmh.
Create this test in rc and watch it in the old 100-200kmh tests.. :smile:
I see 15/16.5sec for 100-180kmh with passenger and the old damn clutch..
Stumbled upon this post while searching for gear ratios...:smile:
Had a test of Dynomaster today with my friend (80kg & 93kg me):
100-181.71 km/h = 15.9s
Ahahahah the 100-180 kph..
That software works with gps rene?
I need to make a test on the german highstreet.. In monza at 100kph i was in lesmo2 turn..
In the end of this mounth (30may) my 197 come with me for my wedding mates!! Ahahah you'll see particulars picture on here aahahhaah
