:scared:
i just make a little resume of my r27
•Coilover suspension by H&R
•Adjustable TopMount MC Motortecnica
•Carbone Lorraine Rc5+ Front Pads
•Goodridge brake line
•Ate sl.6 dot4 Brake fluid
•Bardahl 5w40 Engine Oil
•Bardahl 75w90 Gear Oil
•Inlet manifold worked
•Airbox Clio Cup/Clio v6
•Air filter Green
•Head engine worked
•Balanced crankshaft Clio R3 250
•Cams Clio R3 230
•Piston Clio R3 250
•Conrods bolts Clio R3 250
•Saenz steel conrods H
•Bottom upgrade engine mount
•Cablre throttle Clio Cup/Clio R3
•Steel flywheel
•Reinforced pressure plat
•Quaife differential
•14/69 Couple
•Engine balancing
•Y Pipe (no first cat)
•Cat 200 cells Brain
•KTR Exhaust
•GetData Ecu with 2 map (1 with wideband autocorrection)
•Zeitronix Zt-2 Wideband
•Engine room mapped
•Air Conditioning removed
•Radiator liquid moved, in stainless steel
•OZ Ultraleggera 17” 8j matt black
•Xilema wheels rods
•Toyo R888
•Oil temperature gauge AEM
•Steering Wheel Renault Sport
:bounce1::bounce1:
