CallorFold
Posting just to keep up to date with this thread. Seem's likely I'll be getting engine mounts changed on mine Friday next week along with Gearbox Oil change. I'll be going with OEM mounts.
i have just fitted upper torque mount and upper engine mount insert and the car changed into what i would call a sherman tank. there is too much vibration for my liking and now there is rattles at different engine speeds. the rear view mirror blurs at certain speeds when driving , vibrations on wing mirror and blurring, you can feel vibe in the seat,.
has the jerk come back?I've had a small engine jerk due to play in the upper dog bone mount (I believe it's this one) so I changed it to a new OEM mount. About 100 km later (!) I opened the bonnet and had a feel, and there is a bit of play all ready!! I can't feel it when driving the car, like the last mount, but is there supposed to be absolutely no play or is a little play normal?
No, haven't checked the other mounts. Are they difficult to check/expensive to buy new OEMs? Could that be the reason the other mount has some play after just 100 km?Have you checked the other mounts?
Should I considered the top mount that I just changed ruined? The car is going to a garage in about a weeks time so I'll ask them to check the dog bone. If this is worn, should I replace the lower dog bone, and the upper one once again, or will replacing the lower one make the play in the upper mount disappear?From experience the mounts don't usually wear out one at a time. If you replace the top usually your would need to at least check the lower dogbone. Any shop with a lift can do it.
Mk3 Powerflex Engine Mounts | Car Parts For Sale | 0 | |
Fitting a turbo engine - Clio 197 | Clio 197 Area | 3 | |
| O | OEM Engine Loom and ECU | Clio 197 Area | 1 | |
New Engine | Clio General Chat | 1 | |
| E | 197 Engine mount movement, normal? Vid inside. | Clio General Chat | 8 |
