Id certainly be using it at the red light of the pit lane...popping and farting away till the light goes green :evil:
I can't wait to hear an aftermarket exhaust with the launch control
I drove K-tec's 200T yesterday, one thing I have to say, the torque is nice!
How does the gearbox limit torque? Is this the mechanical limit of the Getrag gearbox (as in, it breaks if you shove more torque through it) or, is it a clever electronic torque sensing widget that talks to the ecu and throws a paddy if you endanger the gearbox?
Also, in terms of horsepower limit, is this more a question of heat buildup in the gearbox? Could the gearbox oil be cooled or something?
- presently sat by a pool in Florida - just thought I'd say that.
the limiting factor in the gearbox will be gear/teeth strength and bearing capacity and also the actual torque loading the clutches can handle..
heat will only be a factor I would say when its doing launch control
like a lot of items in modern cars they are built to take a certain limit/life/cost and these days very good at doing it - its only as strong as its weakest component!
I guess we'll find out its limits soon enough. I realise teeth/bearings etc have limits, but wondered if in this case the 'box was electronically protected in some way....
It's a shame Renault/Getrag don't use the same logic as BMW. The gearbox in an e36 325 is apparently good for 800 bhp, same goes for most of the BMW gearboxes. It's like, to BMW, it is totally unthinkable to have lots of gearbox failures. Renault are like, meh, we might get a few back...
K | Lambda sensors for late model Clio 200 | Engine, Gearbox, Exhaust and Air Intake | 0 | |
Clio 197 bad splutter a 2000. Kangarooing | New Members | 3 | |
Clio 197 For Sale | Clios For Sale | 0 | |
Clio 197 / 200 remapping kit........ | eBay Finds | 4 | |
Clio Mapping | Clio General Chat | 19 |
