Chris's LY 200t.
think if you ring them Chris it may be a better idea..some sites tell you lots of b*****s..
then ultras would stick out 7mm more and the sparcos 10mm more?
the sparcos yes, but the utras being 8 inch wide will stick out 13mm.
what size tyres are you running, chris? 205 or 215? 215's on an 8 inch wide tyre will fit.
What you thinking of doing with the original wheels curious whether 200t allots fitting on a 200... hmmm
Different PCD mate - 200s are 5X108 and the 200t is 5X114.3
What size / width / offset do you need for your car ?
:smiley:
17"
7.5J
114.3 PCD
Standard is 7.5 with 55ET... But theres room to go out a little so anything up to I imagine 40ET would be ok...?
Theres like a million pages on eBay so I struggled - so I ask the master :smile:
Also imagine ill need spigot rings with aftermarket alloys??
I know that if you go with Autec Wizards, they'll send you the correct spigot rings and a set of wheel bolts. I would imagine most other companies sending spigot rings too, especially considering how much a set of alloys cost!
Reactions: Pav
well, there's always braid. made to measure (so you can choose ET) and certainly not as expensive as OZ. but, they're more function over form. here's a rally 4RS with fullrace A's ...
Don't want to dilute Chris's thread. So get some pics up, show us, tell us all about them somewhere !!!
No dilution here mate - post away :smiley:
Thanks mate, they are very 'racecar'... Which is great if its a track car but its not...
Reactions: DS197 and peter
Shame about the OZs not being able to fit bud, however I do like the look of the Wizards as the alternative. That modding bug bitten you again after the map :wink:
