Hi mate, I got my lines from here. Found some for your meg toohttp://www.camskill.co.uk/m50b0s408...Brake_Line_Kit_-_Renault_Megane_Mk3_RS_Models
also got my brake fluid from them too.
Nice one, thanks, I'll take a look
K-tec do lines as well.
Its kinda hard to describe, but if you still struggle then say and ill go do it again and take some pics for you
Black headlights needed like Mentalpens!
Love it Steve, what a perfect upgrade.
Cheers Lee!
Yeah i'd like the xenons with black surround but not in a huge rush for them. Once i've got other bits sorted i may then look into it and see if they are much hassle to do
I've also had my handles done black like they were meant to be and I'm considering having factory rear tints sorted.
Xenons are simple to fit although getting self levelling would be an issue I think but I've not explored it yet. In fact I'm yet to sort my second custom loom lol
RUK paid for the handles as they should be OEM but due to the disaster in japan there was a supply problem so they fitted keyless ones.
Although the keyless function doesn't work.
Iirc they are less than £30 a handle tho.
I was advised against having the ecu reprogrammed by the tech, instead I'm just creating a custom loom for each side. I have done one and just need to find time to source a part to do the other.
I paid the dealer £20 to fit my DRL kit whilst they did a loom check under a recall.
My xenon loom
I guess it depends on the dealer with regards to the fitting but they make you sign a waver.
You don't need a custom loom like I have done provided you don't mind chopping the original one.
All it requires is the 12v wire and earth fitting with a anti flicker decoder and with an optional inline fuse.
I didn't want to so I'm making custom looms with those bits sat in the middle and connectors on the ends making them plug and play.
Not sure on the handles, I had a large area of the car re-sprayed ( as has yours) and the bumper strip aligned ( as has yours
) so I got them changed at the same time.
PS yours was not involved in any accident, we had issues with none matching panels and had a long episode helped out by member smithandroper who sent the fuel filler cap off to France to have the paint analysed to get a proper match.![]()
Ta da £10 posted just need an anti flicker resistor and fuse soldered in. I only have one.
I also have a Xenon light for spares on the bay and I will be putting another on that has the corner of the lens broken this week both offside.
Replied to your mail mate.
@Stevoox i've just been looking round my 200 and the rear cluster and associated loom are the same plugs required (male and female).
So you can just go on ebay and buy a smashed cluster & ask them to cut the male plug off with some of the loom off one thats been broken up for spares :thumbup1:
Bye Bye Clio | Clio 200T Area | 10 | |
| C | Goodbye Squee (197) hello... | Clio General Chat | 14 | |
Goodbye Clio 200 :( Hello Focus RS :) | Other Marques | 31 | |
Goodbye Black 200, Hello Megane 250 | Other Renault Sports | 55 | |
| R | bye bye 200 :( | Clio General Chat | 30 |
