needforspeed
Gold Member
Thank you! It will be when it's finished!Proper tidy solution that!
Thanks buddy! Because they just move around and generally leak before they've been boosted so just welded the original hole up and used these fittings. Not a chance of any boost leaks that way. I'm using the red spring.Lovely build, nice attention to detail!
Why did you not go for a MAP sensor that fitted the existing position? I’m looking to SC mine and was just going to get a 2.5 bar sensor from a DCi.
Which spring rating do you have for the BOV?
TIA
Oulton park next Saturday the 12th? Im there and.would really like a look at this mate .
Have you have any oil leaking past the seal on the SC? From what I’ve read you need to mount the reservoir and filter lower than the shaft of the SC?!
Did you make your own intercooler and pipe work?
