You'll need a 12mm hex key to remove the caliper bolts, they are an M14 thread. As for bedding in it all depends what pads your running. For standard I take it easy for a few hundred miles. But for DS2500's for example the bed in procedure is go out and give them loads of grief, let them cool and your good to go, has sumin to do with the resin that bonds them.
