Addison
He's a tight sod, doesn't part with his money these days!If the shoe fits....
Hopefully a replacement arrives shortly and I will have a look and see if the fitment is still the same. There's clearly something off with the design as many people are having issues with it.There’s definitely something wrong there, it looks like the centre post has been put in the mould wrong and the position of the hole has changed.
What’s your address and I’ll organise to send you a new one out?
For anyone interested, I contacted powerflex regarding the upper engine insert. This was the response from them.
@burrellbloke could this be the issue you're having?
Well, I was struggling to get the insert down one side of the mount, but it did look like the square hole was not going to line up.
The spare eBay Renault engine mount is going to turn up by the end of the week (hopefully). I will put the insert in to the freezer smear some white grease all over the contact areas before I try and squeeze it in. If it does not go in I will speak to PowerFlex. I bought the insert around July or August 2020 so I hope they have not been selling the wrong design for the past year or so.
@Addison Was your engine mount a violet one - did it have a thin strip of violet/purple colouring at the top of the square edge that butts up against the engine where the screw passes through?
Mine was similar, although there's paint rub on the spoiler from years of it touching. Had to switch it instantly. Aerial works fine whenever I've used it, but I hardly use the radio in fairness. It was more to save the spoiler!Lovely car, RB is incredible!
I don't suppose you have a link to the stubby aerial you used do you? My aerial's been bent by the cup spoiler - makes the car look like a big RC model
https://www.amazon.co.uk/dp/B07JHMTVYN/?tag=clio197-21
Yours should be easy in comparison haha, hopefully you can get away with just putting in the radio and monitor then configing on CLiPNightmare! Glad you're up and running now. I just hope I don't have the same sort of problems when tinkering with mine [emoji23]
Where does it end? 2003 Clio 172 | Projects & Progress | 1 | ||
S | S88THL - Supercharged Clio 200 | Projects/Progress Threads | 3 | |
Wiring Diagram for 197/200 Wipers | Body Work and Exterior Lights | 1 | ||
S | will a 197 diffuser fit on clio 200 | Body Work and Exterior Lights | 16 | |
Addy's Daily 200 Project | Projects/Progress Threads | 47 |
