I had only stock cars in mind :biggrin: there is much more to this but I didn't want to bother with the "details". There are two different ways you can go to limit the revs. Either you go for spark retard or fuel cut. Both can be programmed very specifically and here you have the lower/upper rev limiter too so you can set the limiter just the way you want / need (different EMS have different options).
You can set the rev-limiter to be very "gentle" so when you reach it there is no sudden stop of the power going to the wheels.
If your powerband goes all to the rev-limiter then why do you have it there? At some point the engine losses power due to weight of the components, the VE, cam duration/lift,...etc. and personally I would or better I'm going to put the rev limiter on my project car 200-300rpm after the car reaches it's peak power so if I miss to shift at the right time I still won't be hitting the limiter. The engines momentum will drive it does few revs higher so the power-drop won't be so huge after reaching it's peak.
Could go on but then this would become a novel :lol:
I know!!! You dont need to tell me!
I have it there as I dont need it any higher, not good for engine life no matter what anyone thinks, a mate of mine runs a Clio X85 Cup racer and also wrote and built my ECU. He knows more than all of us put together!
