CL10 CYA project
Also toke it into work for the Nightshift
Came out to rain so that was a fun drive home
Next on the shopping list
New tires - debating what to try next and size
Powder coat the gold set of 8j
Then off for a full alignment
And guess I need a trip south for a Map
I always had it in my mind I was going to fix this and sell on to make a few quid and finally make that move away from CS and get into kit cars
However jezo it's way too much fun
Scares some proper big modern cars proper little hooligan motor
Reactions: Onrus and Sean197
So loom day
What a long day that was
Garage was down to 0.6degc today with the sun on the garage
So took over the kids play room
Was not as straightforward as copying over looms, then we made a mistake of not marking a couple of same coloured wires before stripping the plugs down, so then had to hunt down wire ends etc
Anyway got done in the end
View attachment 159199View attachment 159200View attachment 159201
The end result
seeing as though you've done all this loom work you may have the answer to a question of mine.
The two relays in the fuse box thats usually located at the front of the battery, these arent needed are they? They are usually for headlight washers I think.
Ive done a battery relocation and want to make another custom fuse box to replace the box with these relays in so if I can ditch the relays it would make things easier.
I can't remember now.
I mounted that until to the abs unit in the back of the bay
I am away on holiday tomorrow so can't even look for you until I am back
