TB Rich
Just wondering if anyone is using any of the genuine competition Renaultsport stuff, and how much we can use assuming stock subframe and steering rack are retained?
I don't want to change one thing only to then discover to make it work actually requires a bunch of other bits I'm not interested in more pioneering efforts!
So I guess the idea would be use these bits:
I'm sure it'll probably transpire that the only sensible option from Renaultsport is the R3 Access coilovers as I seem to recall the Clio Cup Michelin road series cars are just using these with no other substantial changes?
However for the actual dampers and springs I'd probably use the Ohlins kit anyway rather R3 Access, but I want to know if there's any fancy bits we can use in-conjunction with? Something beyond just basicly coilovers?
EE brackets | Restore wishbone angles (think that's what the EE bracket is for?) | Concern over needing wishbones, driveshafts, arb links and anti rotation links too? |
Rack shims | Restore track rod angles for bump steer | These should just fit independently? |
Lower subframe brace | Stiffness | Maybe need the subframe? Probably not even needed and maybe easier to use the Ultra Racing lower brace? |
Subframe link supports | Stiffness | Maybe need the subframe? Not sure where the other end of these attaches either, so how easy to fit? |
