Surface rust on the actual disc that the pad comes into contact with? Or rust around the hub?
The rust around the disc itself where the pad makes contact is normal and usually appears when it rains and will disappear after you drive and brake a few times.
If you mean the rust around the hub then get some Hammerite, clean it up with a wire brush or something and just paint straight over the rust
Thanks for the replies, as you point out I should have said that it's specifically the discs I wanted to clean. (The hubs are fine) The rust is quite thick and uneven rather than just the usual discoloration which is why I'm hesitant to use the pads to clean it off!
Doing a few gradual stops not applying the brakes too harshly should get rid of it all, just time your take and start off slow just in case the rust stop the brakes from working as effectively as they should
As said pads will clean the discs if it's the face you are talking about. It won't sound nice at the start but will clean up nicely. A brake service after that would be on my list.
