What height for my B14’s on 197
Discussion in 'General Chat' started by Moono16v, Dec 9, 2018.
  1. Moono16v
    Moono16v
    47
    Car:
    Megane 250.
    Good morning all, I’ve had my B14’s on my 197 now for around a month and only done one track day on them.
    My question is what ideally should I have them set at both front and rear?
    I currently have rears all the way down and fronts around 6-8 threads left. It felt okay but it’s terrible on the road.
    If I put them all the way up will it become softer for it as a daily?
    Many thanks
    Elliott.
  2. Moono16v
    Moono16v
    47
    Car:
    Megane 250.
    Anyone??
  3. Pav
    Pav Moderator
    11,601
    Manchester
    Car:
    albi blue 197 with boost
    the ride will remain somehow the same..i was half way down on both ends (give or take) and driving around Manchester was ok-ish...
  4. Moono16v
    Moono16v
    47
    Car:
    Megane 250.
    Didn’t know you was in Manchester mate. Whoever said they are a comfy ride are talking bollocks
    lewishunter98 likes this.
  5. Dumdum
    Dumdum Gold Member
    703
    near mansfield, notts
    Car:
    Renault Clio RS200 CUP/fiat ducato campervan
    Wind the rear up a little and have the rear higher that the front by about 5mm by the jacking points...
    Why people insist on lowering the rear of cars on coil overs to the floor and having cars level... or worse arse end down... I will never know... every front wheel drive car Ive ever setup has benefitted from the rear being a touch higher, moreso with the French marques to tame the liftoff oversteer you have to find a sweet spot between turn in and over steer...
  6. Moono16v
    Moono16v
    47
    Car:
    Megane 250.
    The rears all the way down and it still sits higher than the front
    So it’s just and I mean just nose down.
  7. Dumdum
    Dumdum Gold Member
    703
    Car:
    Are you assuming by wheel arch gap or have you actually measured the jacking points and set it to standard less 30mm or whatever all round?
    That’s where I would start...
    Is it on the bump stops by any chance? Do you have to modify them?
    The rear will always be stiff for the most part in a front wheel drive car, it helps turn in immensely, and since the rear also doesn’t have any weight about it it will seem a little bouncy to a degree, too stiff and it skips, but it’s a track oriented setup vs normal cup springs say...
  8. lewishunter98
    lewishunter98 Paid Member
    401
    Southampton
    Car:
    Racing Blue Clio 197
    This is how mine sits, essentially the same as my H&R springs. I have no complaints on it really! Can be a bit harsh but I'm running powerflex bushes too so that's to be expected
    Has only been a couple days but I think it feels great, can't get over how much better it is in the corners. Pretty sure they're all the way down on the back and theres a fair amount left on the front ed0d8afe9b9626c55c79241e052b6f36.jpg
    Sean197 likes this.
  9. Sean197
    Sean197 RIP Albi :( Moderator
    3,484
    Fife, Scotland
    Car:
    Albi 197T - RIP, MK7 Golf GTD Sports Wagon
    Mine was all the way down at the back with quite a bit left on the front, and felt ok. Little more bumpy than standard but it's to be expected from stiffer suspension.
Share This Page
