v6 airbox mod?
What are the advantages of using the V6 Airbox please?
More power/torque, better intake sound.
One of the best mods that I've done.:jase:
EDIT: Do it in the combination with the matched inlets and a proper remap and believe me - you WON'T be disappointed!
After 5000rpm it's a different car just with the V6 airbox.
Im sure i've seen people fitting these and baffling as it is, they lose a couple of bhp on dyno testing. hmm just speculating here.
I'm one of them, though the ECU is causing it. I'm 2bhp down but the ECU caused a 'glitch' in the power runs due to the extra air.
With a re-map it seems to add power and torque.
I was waiting on this new K-Tec ECU but that doesn't seem to be happening so I'll probably end up re-mapping the standard ECU.
Haha i've been waiting for that since Jan 2009 mate, when it was just a month away from production, hmmmmm.
The Ecu can be correctly mapped if you take it the right people. I remember Kevo had a similar problem with his modified airbox and running lean.
The same thing I'm having now with the matched inlets. I need to remap the car again. But even with running lean it produced 3bhp & 5Nm more, but in the lower revs there is even more.
Damn Sagem3000 and it's lack of self correction.
Its abit of a pig to work with from a modifiers point of view.
Personally i just got everything fitted at once and had the remap to suit the setup, and just left everything alone.
I agree, but didn't have the money to do it all at once, and to be honest - didn't think I would go that far with the mods. :smiley:
kevs ran bad cause the cams wernt fitted correctly and get changing the timing. and went about it the expensive way to fix it by getting a new ecu. once the cams were sorted it was fine
kevos running lean was due 2 it continiously running the cold map due to a faulty temp sensor.
Well it appears people have several different stories on his situation, and I'm not exactly sure what the case was. However I can only go off what hetold me in person at fcs two years ago.
P.s appologies for hi jacking thread :tongueout:
its was faulty tenp sensor just before he sold it. He did av probs with cams at some point before.
