Corrected power are the curves you see. Calibration is a bit out though. Changed it today to read a bit less happy. 335ps and 380nm corrected at the moment.
Hows it driving buddy ?
Drives awesome mate, torque comes in a bit late to my likings though, 380nm at 4000rpm right now. It does come in really gradually though, which means it grips second gear no problem!
It's lovely not having the power drop to redline, that's what i hated with my last setup!
Sadly the dyno is closed for the next few weeks but i'm on the edge of the injectors and fuel pump anyway so going to change them first, recalibrate and then try some more boost![]()
Nah mate, i want the torque to be way higher still!!
Will post the current graph tomorrow as i need to upload it via my laptop
WFT is that !!!
Have i just been culled.........?
I'm not quite sure but I like it. Here's my other
And this is jimmys, notice the theme with each other's...
"Gentleman - chose your weapons" !
You're like a character out of COD Chris
Arrrrrrrrr.......look at Jimmy's : the little ray of sunshine he is.
Just signed up to the forumSo why don't i know you then?
I currently drive a Racing Blue 172, which is for sale on marktplaats. Im looking at several Renault Sports as a replacement. Mostly 197's. Won't be as extreme as yours tho, lol. Probably a similar (or slightly better) setup as my 172. (Basicly fast road setup, maybe some semi slicks added in there)Hahahah, it sat on my parents deive for that week as i was away for work.
It álso has all the basic mods yeah
What car do you own?
Bit of a long due update but been kinda busy with the car last week! Also decided to make a flickr account to be able to post some pictures again after the photobucket debacle.....
I had some annoying teething issues which showed up on the last moment. Had to remove the fuel tank again and also the fan didn't seem to be working properly. After having those sorted i took it for a 200km round trip to and from work. During this she performed faultless so i was confident it should do the 1000mile round trip to FCS aswell.
A few pictures shot at the event:
Tbh i found FCS pretty dissapointing, been there a few times in the past but this time round the organisation was horrible! better be doing an other event next year!
On a positive note though, i got invited to do a photoshoot for the PFC magazine, sadly it won't be a cover feature as their policy is not too cover foreign cars.....
So what is the current, technical, setup of the car:
Megane 250 engine which covered 80kkm, incl megane 250 throttle body (+ boost hose adaptor made by Ste_R26)
Borg Warner EFR 6758 turbocharger on a T25 tubular manifold + all connections custom made by me
R26 gearbox with R26.R clutch and SMF
Fully handmade 3" turbo back with loudvalve
Megane 250 intank 550kpa fpr and megane 225 pump (temporarily), std injectors for now.
Airtec 95mm FMIC, modified because of bad fitting on Clio
Forge hardpipekit also modified because of bad fitting on Clio
Handmade 2,5" stainless inlet tube with Ramair filter
Oil catchcan
upfront new Megane 250 cup brakes and at the rear new Original brakes, fitted with DS2500 pads alround
Motul RBF600 brake fluid
In the ecu i've changed the fuel injection so it accounts for the rising rate fpr at the rail, knocked up base map for fuel injection itself to get me to and from FCS in a short notice.
Ignition map loaded with a meg 250 one, slightly altered to make up for the missing vvt.
Boost duty set to zero so i could drive it around without having too much risk of overboosting considering i haven't properly mapped it yet.
Hopefully i'll be able to put it on the dyno next saturday to properly dial in the part throttle maps, maybe, just maybe i'd have enough time to do some boost mapping aswell![]()
