Bit of a long due update but been kinda busy with the car last week! Also decided to make a flickr account to be able to post some pictures again after the photobucket debacle.....
I had some annoying teething issues which showed up on the last moment. Had to remove the fuel tank again and also the fan didn't seem to be working properly. After having those sorted i took it for a 200km round trip to and from work. During this she performed faultless so i was confident it should do the 1000mile round trip to FCS aswell.
A few pictures shot at the event:
Tbh i found FCS pretty dissapointing, been there a few times in the past but this time round the organisation was horrible! better be doing an other event next year!
On a positive note though, i got invited to do a photoshoot for the PFC magazine, sadly it won't be a cover feature as their policy is not too cover foreign cars.....
So what is the current, technical, setup of the car:
Megane 250 engine which covered 80kkm, incl megane 250 throttle body (+ boost hose adaptor made by Ste_R26)
Borg Warner EFR 6758 turbocharger on a T25 tubular manifold + all connections custom made by me
R26 gearbox with R26.R clutch and SMF
Fully handmade 3" turbo back with loudvalve
Megane 250 intank 550kpa fpr and megane 225 pump (temporarily), std injectors for now.
Airtec 95mm FMIC, modified because of bad fitting on Clio
Forge hardpipekit also modified because of bad fitting on Clio
Handmade 2,5" stainless inlet tube with Ramair filter
Oil catchcan
upfront new Megane 250 cup brakes and at the rear new Original brakes, fitted with DS2500 pads alround
Motul RBF600 brake fluid
In the ecu i've changed the fuel injection so it accounts for the rising rate fpr at the rail, knocked up base map for fuel injection itself to get me to and from FCS in a short notice.
Ignition map loaded with a meg 250 one, slightly altered to make up for the missing vvt.
Boost duty set to zero so i could drive it around without having too much risk of overboosting considering i haven't properly mapped it yet.
Hopefully i'll be able to put it on the dyno next saturday to properly dial in the part throttle maps, maybe, just maybe i'd have enough time to do some boost mapping aswell
