TRS Material Tow Loop
The best way to do this on a 200 is to probably remove the front bumper, bolt the strap on (You'll need to find out what thread is on your current towing eye first) then put the bumper back on feeding the strap through the hole at the same time.
Only problem you could come up against is the threaded hole being too far into the bumper (Which I think it would be). Its a good 5-6 inches inside the bumper.
If you can get it to work I might get one to lol.
nice work noddie cheers for that!
Tbh, I think the way Ben put his on looked better. Only thing that would make it look even better would be to modify the towing eye cover in a way that will allow you to clip it back in.
that looks in a completly different place to the 200
they havent even been posted yet so you will probably get yours before i do kdl87
