Hi chaps.
Want to purchase a torque wrench but not too clued up. Primarily going to be used for changing wheels.
1/2” drive looks the way forward.
Anyone recommend me something?
Don’t want budget or top end products though!
Thanks in advance
Eagerly watchingDo you use it on your wheels mate or for work? Quite cheap. Looks ok thoughi got mine from screwfix. Is well made and comes with adapters.
https://www.screwfix.com/p/reversible-torque-wrench/18289
tho at second glance the amazon one looks to be the exact same.
i use it for the wheels and any other bits i need.Do you use it on your wheels mate or for work? Quite cheap. Looks ok though
i certainly did..awesome thing to have..it even sorted @Benno's stubborn spacer bolts!!This is what I use chaps, and it’s bloody excellent.
@Pav used it at Bedford.
It stays in the boot with a 17mm socket for any wheel issues!
Laser 0316 Torque Wrench 1/2"d 42Nm<210Nm https://www.amazon.co.uk/dp/B0012M9GC8/?tag=clio197-21
Cheers Foxy1/2 drive & up to 200nm should see you good!
just remember once used wind back to 0 so it doesnt go out of calibration
Cheers boss. Doesn’t seem like I need to spend a great deal of money on one. Good news!
Personally, i would think twice before buying 18£ torque wrench.
Okay, if only job is torque wheel bolts maybe then it will be fine..
I have :
Biltema 1/2" 40-250nm
Proxxon 1/4" 4-36nm
Those were something like 50-80£ / each and shipped with calibrating papers.
I've got the Halfords Professional one.
Great build quality, nice tactile feel to it.
http://www.halfords.com/workshop-to.../halfords-professional-torque-wrench-40-200nm
I'm using one of these for the past 18 months, like you say comes with a case and cal cert. Regularly check it with my friends more expensive and calibrated torque wrench to make sure it's still close enough to what I need it to be.Another vote for the Laser Tools 1/2" torque wrench from me. I picked mine up from Toolstation when it was on offer for about £28. Awesome bit of kit, came in a moulded case too with a certificate of calibration too.
| T | Torque setting for ring gear to diff? | Engine, Gearbox, Exhaust and Air Intake | 1 | |
Rear axel "pockets" torque setting | Clio 197 Area | 1 | |
Clio 197 rear disc torque settings | Suspension, Brakes & Steering | 2 | |
Sold: Draper 3005A 3/4” Torque Wrench | Non-Clio For Sale | 3 | |
| S | Torque wrench.... | Wheels and Tyres | 12 |
