Too much castor
PITA
Does anyone know why my front wheels sit so far forward compared to others?
@Foxspeed I’ve heard your the wizard
Drivers
Passengers
I was trying to compare mine to PITAs, he has Cooksport springs (so ~30mm) I am on Eibachs (~25mm), i've had both arms changed, I don't think they do, but do 200's run more caster than 197s?
EDIT: also thinking about it, could worn anti-rotation links cause more caster too?
All the ones I’ve worked on, and my own are all like that. It’s just more noticeable with you having et55 wheels and big tyres.
Reactions: suj
Mine has worn holes through the arch liner and skimmed the edge of the bumper almost to a sharp point
I've got 20mm spacers (so 7.5" ET48) with 225/45/17...it has some caster, but doesn't his seem really far forward, especially drivers side?
Not the best angles but this is 7.5j & ET50
running some camber so that helps And these are 225/45 ar1 so serious side walls
Don’t know if it makes much different but also on coilovers but the height is the same ish
DD783827-9991-4375-AA73-7A3C85DEE6D6.jpegE4CFBA1B-851C-427A-B92F-DAF05D3A9D16.jpeg2DEE0149-5EC1-4D32-849C-C09DFB909405.jpeg
Reactions: R20BTG and suj
