thermostat
I've got my belts due in the next month or so.
I've tried to book it in at SJM but he's not been answering for 4 days now.
Anyone got any other options close to Chippenham?
Well not that hard... Ill look for a guide around the net for you
Edit
I found this one:https://youtu.be/_oKCj1c4M2Q
Pretty much the same as i did except that i didnt remove the battery(faster way but not that comfortable) if you about to full drain go for the lowest point in the radiator and drain it all ( under the thermo housing there is some electric wiring so be caution)if you go like in the video so put something under the thermo on the electrition ( some water wont hurt it but still..) good luck!!
Oh and if you dont full drain p
Once you open the termo house lift up the pipe so youll not lose alot of liquid .the block has some too
And after you done let engine work to operation temp so the water will flow correctly and then top up + go for a ride 2-3km and then top up again [emoji122]
