Also what is that thing they do with photons where they shine a single photon through a slot and it breaks apart? Quantum Entanglment?
I love the double slot experiment, it shows how mental quantum physics is quite easily. It demonstrates quantum interference (entanglement is something different, more complicated and even more bonkers).
The principle is that you shine a light through two slits onto a screen. Logic would suggest you'd see two patches of light on the screen, perhaps overlapping depending on the distances used. However, what you actually see is light and dark stripes of light. If you imagine that light is a wave then this starts to make sense.
Imagine dropping two pebbles into a pond a distance apart. The waves from each will travel outward, and eventually meet the waves from the other. Where a peak meets a peak, or a trough meets a trough, they will essentially add together to give bigger waves. Where a peak meets a trough, they will cancel each other out and lead to a flat patch.
If you look at the light travelling out from each slit as a series of waves, they interfere with each other like the ripples on the water to create light and dark stripes on the screen.
There are some good diagrams of wave interference that make it a bit clearer
here.
That all makes sense and isn't too alarming, right? I mean, we're taught at school that light is a wave.
What's fun is when you start firing particles (such as matter that actual, physical things we can see and touch are made of, or something smaller like photons) at the slits. What you see is the same interference pattern whereby you get stripes of particles hitting the screen. But that makes no sense, because they're particles and not waves. In fact, one of the principles of quantum physics is that particles and waves are just two ways for us to interpret the same thing, and describe how they behave in certain situations. Even matter behaves like a wave in certain situations.
Weirder still, is that if you put a particle detector at the slits so you can measure how many particles pass through each of the two slits, the interference pattern disappears. Observing the particles on their journey actually changes how they travel. Now we're getting really crazy
The most "popular" theory of what is happening is that every particle is taking every possible route from the source to the destination, of which there are an effectively infinite number, in different "dimensions". When something observable happens, this collapses and we end up back in one dimension. This is the basis of "quantum wave functions" and "wave function collapse".
Let me know if any of that is badly explained, because when you realise what it means, it's a pretty mind-blowing idea
