Anyone had any issues with either the shock absorber or the top mount knocking ? Got slight play in the NSF when the car is on the ramp, can be heard when driving on slightly bumpy roads only
front suspension is quite complicated and theres a few ball joints and links that can wear and make noise so its best to have it checked rather than just asking and guessing....:s
Did you find out what it was mines the same, knocking from n/s/f over bumps potholes etc but I can't get any play when it's on the ramp so cannot find the worn part ?
I had a similar problem when I first bought the car, garage couldn't find any play or movement in anything. In the end they put a shock absorber on it on the NSF and the knocking was cured!!
