I have some good news and some bad news....
Bad news the Clio won't be used on track
The good news, the Clio won't be going any time soon
In other good news....I bought an E36 328i track car in Boston Green....YAY!
Feels like deja vu, as I owned one in 2012 that I turned into a track car, but I didn't get to use it on many tracks before I lost my unit and at that point in life I could have done with the money, so I broke it for bits and sold the car to a mate, who put interior back in and then sold it on to someone....who then sold it onto DannyDC2 (some of you may know of Dan from youtube and the like, small world as we knew each other on VW forums from back in the day when I was at uni).
Here's the old one
Enough about reminiscing....
So the new car and why I bought it, I have missed it since I sold it, I regretted it for a very long time and I have been seeing prices go up loads (E30s have gone through the roof so they were off, E36 M3s have gone super high now, so that meant E36 followed suit), I really wanted Boston Green as I think it's genuinely one of the nicest colours for an E36, I really loved the M52B28 engine too, it also is a strong engine with hardly any work needing to be done compared to the S50B30 or B32 in the M3s (also I think the M52 sound better).
I have kept an eye out, but nothing had really done it for me, I was originally looking for a standard one then I wanted to do the work, but nothing had popped up and many others now wanted the Boston Green ones, so they were in high demand!
Then this popped up, it had many of the mods I would have wanted to do, so here is the spec list from the sale ad:
Engine and Gearbox:
-BMW Motorsport LSD with 3.91 Crown Wheel and Pinion
-K&N Filter
-Scorpion Exhaust
-BMW M3 Radiator and Header Tank
-Recent Prop Donut/Centre Support Bearing Replacement and Prop Shaft Balanced
Suspension and Handling:
-HSD MonoPro Coilovers 10kg/12kg Spring Rates
-VAC Rear Camber Arms
-BMW Z3 Steering Rack (claimed)
-Polybushed Eibach Front and Rear Anti Roll Bars /w Polybushes
-Polybushed BMW M3 Front Lower Arms
-Polybushed Rear Suspension Arms
-Powerflex Black Diff Bushes (19.09.20)
-Full Alignment (BM Wizard 19.09.20)
-Motul GEAR Competition 75w-140 LSD Oil (27.09.20)
Brakes and Wheels:
-17x9 TD 1.2 ET42
-Federal RS-RR 255/40
-Pagid RS-29 /w Pagid Discs all round
-Braided Brake Lines
Interior:
-Laycock Engineering "Half-Cage" with Cross-Brace and Harness Bar
-Bimcaro Bucket Seats
-Schroth Harness/OMP Harness
-Driftworks "Low" Seat Rails
-Suede OMP Steering Wheel
-Quick shift /w Weighted Gearknob
Notable recent work includes;
-Reinforced Trailing Arms
-Full Geo
-Front and Rear Diff Bushes
-Front Track Rod Ends
-Diff Oil Change
-Jacking Points have been plated by a previous owner
-Prop Shaft and Centre Support replaced and balanced
-Window Regulators Replaced.
As you can see, it's quite a comprehensive list of mods and not cheap to do them all then on top of that the price of a BG 328i Manual on top, so I contacted the guy and I had a few questions regarding the mods / condition etc. We then setup a phone call and just chatted, he's a proper car guy (has owned a Clio 182 and Megane RS250 just before this), he didn't own it long (~6months) but has spent £4k on it in that time, this put me off at first, but then after speaking to him he is looking to buy a house and as it's a second car and he used it on 2 trackdays where it was faultless, it will now sit dormant for the next 3ish months until tracks open again in new year, so he was hoping to free up cash to put into a house, made me feel more comfortable.
Now the car, mechanically it is brilliant, engine pulls perfect, gearbox is great and smooth, LSD is great and locks well. The underside is clean with all rust spots that normally go have been rectified, this is a big bonus and costs saved.
Then of course the long list of mods, I would have went for the same HSDs (if you look above at the pic of my old on decked, that was on HSDs with their (at the time it was named) "Nurburging Spec Springs", I was the first person to have them, they wanted me to get them on and deck it to see how low it can go....as apparently that was a requirement for their customers.....that wasn't even all the way down haha).
Then things like the Eibach ARBs I had before, everything is polybushed (not expensive, but takes the piss to change them all), the half cage looks really well made too, tied into the rear struts.
Now the things I don't like / want to do:
* The metal plates in the interior dash are horrible, they will be rectified!
* The bodywork needs some attention, mainly front bumper (it was a non Msport like my old one, so has Msport bumpers put on, front one was red so can see it through) also I don't like the bonnet pins in it, so look at removing them
* I am even considering fitting carpet, to make it a bit nicer inside (won't add that much weight)
* Gearstick / shifter, it is so loose and crap for feel, even in a gear the bush has worn so much it has so much movement
* The rack is slightly weeping from seals, previous-previous owner told him it's a Z3 1.9 rack (quickest of all retrofit ones), these cannot be rebuilt, but I will go for a "purple rack" 067 from E46, these are second quickest racks (I did a post years ago measuring them all, how much the pinion displaces per rotation of the input)
* Sunroof blanking plate is slightly leaking (I was told) but I drove it home in torrential rain and nothing leaked...so i'll keep eye on it
* Has a three point passenger Sabelt harness, I want to get a matching Schroth (4pt minimum, 5pt ideally)
* Steering column sits high, so need to look at lowering that
* Set of road tyres (or wet road tyres)
* M3 underbody brace aka X-brace from a convertible (ties the engine subframe to the chassis rails, also adds some protection to the sump)
I've got a few things in the attic from my last one, I got some Turner Motorsport solid slider pins for the calipers, I have 6x R888s (4x 225, 2x 255) so I might buy some wheels to throw them on to use up on track (they've been dry stored, but I wouldn't use them on the road).
Overall I am very chuffed with it, rough round the edges but drives so good, the throttle response just gets me every time, the joys of cabled throttle cars!
So should see many of you lovely people on track soon, please don't overtake me too quickly to make me feel better about myself
(not done a trackday in like 6 years!)
Here's some pics, most stolen from previous owners pics, will do more as I come along.
I've bought a few bits already (currently on the way, some BF deals):
* TD centre caps
* Bonnet badge (common faded one on there)
* New solid short shifter
* Bonnet gas struts
* Rear top mount reinforcement plates
* Fog light blanks
* Aerocatches
So regarding Clio, it will remain as my daily, so I might sell the Bilstein B14s (as I was planning to put them on, to get it out on track), I also have a Rear ARB and few bits I had been hogging I will put up for sale soon.
