looking closely at the pictures the holes do not seem to have any countersink on them this would make some noise . Easy to rectify you can do it yourself in situ with a electric drill with the correct bit in. I would however recommend a better job would be done by doing them on a pillar drill so you can set the stop and get everyone the same. I actually got solid standard discs for my E30 and drilled and countersank mine myself. Much cheaper for me ( but I had access to a m/c shop at the time)you will still get the pads touching the disc face - from the video it doesn't seem to be binding and spins easy - more than likely the new discs have still got a sharp leading edge on the hole/grooves causing the actual noise - even when worn off they will still produce some noise...
