Phenom
So from my last post car still isn't moving....
checked all the earths and is earthing fine, new battery and new starter still nothing.
which leads to my question of where is the start relay? as in the boxes around the battery there was a single 50A relay which I tested and is working fine. is that relay the starter relay? or is it somewhere else as I've got the problem down to 2 things:
1. exciter wire for the starter motor doesn't ever get a signal when trying to start the car
2. the actual power supply wire for the starter is only showing <1v volt but battery is not the problem here.
So is it the starter relay? and where is it?
if not what the hell is it?
Thanks in Advance
Pic of relay I tested
Thanks in Advance
