Help with No Start (does not turn over at all)
jimmybell
It's been sat for some time.
It would historically turn over with a tricke charge or jump pack, and run fine, but knowing the battery was on the way out it wont hold a great charge, so i bought a new one.
  • fitted new battery. this was much harder than anticipated due to the difficulty of fitting the tie down clamp. i could have knocked any of the associated battery box connections (as tehre's a bunch of electrical/ecu stuff surrounding it?)
  • it turned over once, but didn't start. it now wont turn over at all. doesn't even try.
  • dash does not light up, only response to ignition is a whine at top/back of engine bay.
  • hazards work, headlights do not. lock/unlock works.
  • battery has good voltage, jump pack also doesn't help.
any idea what to check? i might try rebuilding the battery box from scratch, but i'm not sure how to successfully fit the tiedown bracket again. it may also be threaded, as that's why i struggled to get it back in in the first place (i don't think that was my doing..).
local garage is going to fail i think, they don't know clios. linked my rambling build thread message on the same topic:
