A2ON
2009 Renault Clio Renault Sport Cup
bodywork
Body Type hatchback
Number of doors 3
Designer
dimensions & weights
Wheelbase 2585 mm 101.8 in
Front track 1520 mm 59.8 in
Rear track 1520 mm 59.8 in
Length 4017 mm 158.1 in
Width 1768 mm 69.6 in
Height 1484 mm 58.4 in
Length:wheelbase ratio 1.55
Ground clearance
Weight 1204 kg 2654 lb
Weight distribution
Fuel tank capacity 55 litres 12.1 UK Gal 14.5 US Gal
aerodynamics
Drag
Frontal area
CdA
engine
Engine code F4R 832
Bore × Stroke 82.7 mm × 93 mm
3.26 in × 3.66 in
Number of cylinders Inline4
Capacity 2 litre
1998 cc
(121.925 cu in)
Valve gear DOHC
4 valves per cylinder
16 Total valves
max power
EEC 200.5 PS (197.8 bhp) (147.5 kW)
at 7100 rpm
NA
EEC 99 bhp/litre
1.62 bhp/cu in
max torque
EEC 215 Nm (159 ft·lb) (21.9 kgm)
at 5400 rpm
Specific torque
EEC 107.61 Nm/litre
Engine construction
sump Wet sumped
compression ratio 11.5:1
Fuel system MPSFI
brake mean effective pressure 1352.2 kPa (196.1 psi)
Maximum RPM
Engine manufacturer Reanult
Number of crankshaft bearings
Engine coolant Water
Bore/stroke ratio 0.89
Cylinder volume 499.5
Aspiration Normal
Compressor N/A
Intercooler None
Catalyser Y
performance
0-80km/h
0-60mph
0-100km/h 6.90 s
0-100mph
Standing quarter-mile 14.90 s
Standing kilometre 27.30 s
Maximum speed 225 km/h (140 mph)
Power-to-weight ratio 164.29 bhp/ton
fuel consumption
Fuel consumption 11.3/6.4/8.2 l/100km urban/extra-urban/combined
Carbon dioxide emissions 195 g/km
Carfolio Calculated CO2 ? 196.80 g/km
chassis
Engine position Front
Transverse
Drive wheels Front wheel drive
Steering rack & pinion PAS
Number of turns lock-to-lock
Turining circle 11.40 m
Front suspension
Rear suspension
Wheel size front 6J x 17
Wheel size rear 6J x 17
Tyres front Continental Sport 3 215/45 R 17 88W
Tyres rear Continental Sport 3 215/45 R 17 88W
Brakes F/R VeDi/Di-S-ABS
Front brake diameter 312 mm
Rear brake diamteter 300 mm
Gearbox 6 speed manual
Top gear ratio
Final drive ratio
general
Carfolio.com ID 197736
Number made
Model code
Model family
RAC rating 17.0
Insurance classification No information available
Tax band No information available
bodywork
Body Type hatchback
Number of doors 3
Designer
Ground clearance
Weight distribution
aerodynamics
Drag
Frontal area
CdA
engine
Engine code F4R 832
3.26 in × 3.66 in
Capacity 2 litre
1998 cc
(121.925 cu in)
Valve gear DOHC
16 Total valves
max power
at 7100 rpm
NA
EEC 99 bhp/litre
1.62 bhp/cu in
max torque
at 5400 rpm
Specific torque
EEC 107.61 Nm/litre
Engine construction
sump Wet sumped
Fuel system MPSFI
Maximum RPM
Aspiration Normal
Compressor N/A
Intercooler None
Catalyser Y
performance
0-80km/h
0-60mph
0-100km/h 6.90 s
0-100mph
fuel consumption
chassis
Transverse
Front suspension
Rear suspension
Top gear ratio
Final drive ratio
general
Number made
Model code
Model family
RAC rating 17.0
