Nice numbers. Goes to show that the engines are pretty close to the mark as standard!WoooHooo!!!!!!!!!!!
Very pleased to hear that my car has been mapped
With the reprofiled cams, airbox, decats and exhaust it has made a very respectable 204Bhp and 167lbft, which ties nicely into results from friends with 402s and the airbox!
Please let me know your thoughts, print out to come later
Be interested to hear how you find it after the map, I'd imagine it will feel pretty epic.Should be awesome! I can't wait to have a blast. It drove very badly after I bolted everything on, not surprisingly!
WoooHooo!!!!!!!!!!!
All about the drivability mate! How's your flatspot? All mapped out now?
Good result and sets a great baseline for the future of your increasingly awesome car![]()
Why the pause in power and torque at 4000rpm?
My printout is very similar from ED
Looks great. Andy's a top bloke at ED. Could talk forever...!
Reading this makes me want to try the R3 access setup! Lol! That consists of a different inlet cam and the timing altered to suit.
BHP graph at the top end is epic Josh. How well does that hold onto the power !!!!
From 6400 odd - 7700 rpm that is fabulous
I know when you've swapped bits around pre-mapping....you might actually be lower than standard (I'm damned sure i was). So when Andy claws some of that torque back and beats standard; the drive home is brilliant.
Do you have any baseline figures for when your car arrived to when it left ?
Brilliant result again buddy. Great figures and im sure its driving awesome now.
Hi dude,
Yes he is going to do a graph with both as it was particularly bad! Probably a concoction of everything, decats and airbox plus cams!
The torque completely dropped off at 2500 with the monster flat spot, they went lean after 5000.
Yeap it's awesome mate, takes a bit f getting used to revving like that (I know it's not much more haha) as to me it sounds like a Honda lol! With the close ratios of the 197 box it stays within the useable rev range, more so with the extra revs. Obviously haven't had it pinned in 5th but up to 5th it feels good. In Mexico [emoji1166]
Although i didnt hit your heady heights of 204bhp.....my graph was flat at the top too. So Andy raised the limit to 7750rpm.
Know what you mean about a Honda ! If your having a bad day and need to feel like your ringing the neck of something - the opportunity is there
Your's must sound epic too up-top. Enjoy !
Well if it's works as well as the maxi setup, it should see decent improvements!Defo mate! These cams are just longer duration standard ones with just 10.45mm of lift.
Like Andy was saying when you have a cam that's already been tested and works with the timing setup they give you it gives you a good base for it.
I won't go into adjusting the timing in any way with more mapping, just interesting to know
