Thanks for reply, I've been looking for a panel like that.
The one on maxi motorsport page looks to have the square marks around were the radio fits but your pics it looks very smooth, is it smooth were you have your switches?
Been following you on Instagram for a while and just came across this build thread, big fan of everything you've done with the car, looks great.
Out of interest, what made you go from the R3 suspension to the AST's?
Fab looking bay. No wonder your posting pics !
Why 15w/50 oil ?
I followed Simo's lead on this! If you think of it in terms of viscosity at operating temps. Viscosity of a 5w40 @ 70 degrees is the same as a 15w50@ 100.
The engine will only be operating at high temps, it will keep the oil pressure similar to the normal expected pressures at lower operating temps!
It's a big jump for sure, but seeing a fair few F4r830 spinning shells I'm conscious of the pressure!
Yes mate the pic is wrong on the Maxi/MC racing site! It's all smooth where the switches are fitted, just some rendering for heater control and hazard switch. I think some of the photos on Maxi are of my Clio
Hi guys,
Here's my big update on the car. I have finished the interior, the camshafts are in and the header tank from a Dacia installed. I have also removed the A/c compressor the cheapest way possible!!
Car should be going for mapping in the next month. For now a bit of loom tidying
Any further pics needed please let me know
A/c delete is the 172 pulley/racer
4pk810sf stretch belt
Idlers and tensioner not needed
Battery is the lithium ion magnetti marelli
Heater is from T7designs
I'm by no means a professional, but it's the best I can do in my little garage!
Hi is there a specific 172 pulley you use mate? How have you found the set up since you did it?
Great mod that. I've seen a few kits but thats such a cheap option! Cheers for sharing. Your car looks spot on mate.
Which cams did you go for? Sorry if you've already mentioned, just couldn't find it.
Any chance of a "how to" on porting the inlet and TB?![]()
Did you do them yourself mate or get them done from elswhere?I made 230bhp on a un-ported dbw throttle body. I did port match the 2 manifold halves though as there's a few hp to be gained from this.
