Any plans to change cams etc etc?
Gave the car a boot yesterday in the wet, granted it was greasy but you can spin the wheels in 6th! hahaha
Just got home, car made 393bhp with standard cams, inlet and throttle body, and is now an animal to drive
-Andy
:jase:
Andy... so you have f4rt of the meggy 225 AND THEN??
I suppose I haven't really explained the car setup:
RS200 F4R Engine, rebuilt with:
-Cosworth Forged Pistons
-Manley Rods
-Cometic MLS Head Gasket
-ARP Head Studs
-200 Head
-Meg 225 Cams
-Dephaser removed
-Meg 225 Inlet Manifold
-RS Tuning tubular Exhaust Manifold
-TiAL Turbine Housing (0.86A/R)
-Garrett GTX3071 Turbocharger
-TiAl 38mm external wastegate
-RS Tuning 3" Downpipe
-Manifold Wrapped with DEI Titanium
-Downpipe Wrapped with DEI Grey
-Turbine Housing wrapped with DEI Titanium Heat Shield
-Bailey Dump Valve
-Siemens DEKA 630cc Injectors
-Fiat Panda Header Tank and Custom Brackets
-Custom Coolant System Plumbing
-Apexi AVC-R Boost Controller Running Boost per Gear.
-Turbosmart Adjustable Fuel Pressure Regulator
-RS Tuning Fuel Rail
-Bosch 044 Fuel Pump
-2litre Aluminium Swirl Pot
-All Teflon Lines
-NGK iridium plugs
-Custom Intercooler and Hard Pipe work
-Miltek Modified Meg 225 Front Pipe
-200Cell Cat
-Ktec Pro Performance Exhaust System
-KW V3's
-17" OZ Superleggera Wheels
-TL4-031 Gearbox with Quaife LSD
-RS Tuning Remap
-Custom Gauge-Pod with Stack Oil, Fuel, Boost Pressure Gauges
393bhp / 325lb/ft
Best Regards
Andy
-Manley Rods
-ARP Head Studs
-200 Head
-Meg 225 Cams
-Dephaser removed
-Bailey Dump Valve
-All Teflon Lines
-NGK iridium plugs
-200Cell Cat
-KW V3's
-RS Tuning Remap
393bhp / 325lb/ft
Best Regards
Andy
Whats the approx cost of the parts you've had to buy? and then the labour ? if you don't mind saying that is.
