tchalikias
After a long time of having decided on the ideal driving position, I had to fiddle with the metallic lever under the driver's seat (the one that adjusts distance from the controls).
So I lift it up and apart from the typical 'metal spring' noise the lever makes, I also get a mysterious plastic thud.
A quick investigation found the culprit: the left-side plastic cover at the base of the seat interferes, by a couple of milimeters, with the lever when it is puller. I checked the passenger seat and the lever there has a clearance of a few milimeters from the plastic cover.
I know this is nitpicking, but is there any way to remedy this? I don't remember this happening in the past...
