Hi,
Firstly merry Xmas!!!!
I have been searching the net as you do for weeks now trying to find help/information/advice/opinions on a stud conversion I am planning on doing
I own a Renault RS Clio 4 Trophy, I live in wales I do not plan on tracking it very much if at all the reason for the conversion is because I am installing the anniversary body kit to the car so I need to run rear spacers 12mm and front spacers 18mm
Now the body kit is is obviously Renault RS performance, Also the stud conversion kit + spacer is also made by Renault RS performance and what seems to be good quality.
https://rsc.oreca-store.com/fr/wheel-spacer-and-stud-kit-for-clio-iv-r-s-rspkegc200220.html
The 2 things I am trying to find out is in the installation guide you will see at step 8 it clearly states torque the stud to 80nm is this not excessive? Every other company that seems to make a kit like this one states to torque to 25-30 ft lbs which is around 55nm why would this be so different? The second thing is would there be any reason these wouldn't be good for normal road use by my wife that drives very conservatively? And not that many miles?
Thanks
Thanks
