Thanks, will try to keep the thread up to date
Two days after I've been to TechnoRing, there was an event on Autodrom Saint-Petersburg. As they care about tarmac, they had tried to minimize usage of track itself(however, included a section with the speed trap), the stage was created using tractor mostly over the safety areas. Stage was a bit faster than previous ones and included much more sequences of turns(not sure about English wording here, I mean not turrn - long straight - turn, but turn-turn-turn) which allowed to use weight transfer in order to get a bit of oversteer without the handbrake.
First attempt was waay to slow, second was faster. For the third I decided to go all-in, and it was so much faster than previous one that I finally felt that I know how to deal with this car. However, 5 turns before the finish I started to get tired and slow. And when the car found the grip on the exit of the turn, I wasn't able to return the steering wheel to the appropriate position. There was a deep snow, huge waste of time(RaceChrono logs show that more than two seconds were lost) and I was upset that I screwed up my best attempt. Two turns later I tried to re-gain what I had lost and carried to much speed in the turn. I was a bit off the trak, but noticed few trails in the deep snow and decided to point the car there...
Two huge bumps, and I feel that there is something with suspension/brakes
There is a thread:
http://www.clio197.net/forum/showth...th-ideas-car-moves-to-the-right-while-braking
Currently, the braking is good on the reasonable city speeds(my daily commute to work is a city only), but after 60MPH I need to brake carefully as car moves to the right.
Been to two local dealers. Alignment is good, braking forces are good, brake fluid changed, calipers cleaned. They say that suspension condition is exceptional. And no one can figure out what is wrong with the car.
Plan to visit the third one and try another braking forces and dampers check. Have no ideas what to do next.
PS realized that I really miss rally-style events, although I have never been good at such surfaces. Some 5 years before I used to have a Clio 1 16v, dedicated for such kind of racing. Right now I don't have neither garage to store and maintain such kind of car nor time to do it. However, still thinking about dedicated cheaper car for it.
For Clio, I plan to stop(not sure I will succeed when next announcement comes
) visiting rough tracks like this, but start visiting frozen lakes when the ice is strong enough.
