Of cause it is its plugged into the obd and uses similar software to what you would on a rolling road only difference is its actually live and not sat in a garage
lol no thats not the difference!
it uses set time/speed parameters to approximate a bhp figure. the downside is, 1) as youve pointed out the weight isnt accurate, and unless yiu measure eveytime it never will be 2)you cant account for aerodynamic losses i.e head wind or tail wind, you cant account for uphill/downhill.
a chassis dyno measures actual force produced by the tyre on the roller, and from this calculates power and torque figures.
they are very different systems,
does the weight you put in efect the calculations that are made??
i presume thats why it asks for a weight yeah??
The weight of the vehicle in question has absolutely nothing to do with the power out put at the wheels.
Also I'm going to post up another graph soon comparing itg and standard filter
On a topic about a "performance analyser" which uses weight/mass as part of its fundamental calculations, you said ^^^^^^.
Which is incorrect. So no, you werent right about the weight in the context of the discussion.
When talking about load-holding rolling roads, then yes, there is no context of usable mass.
HOWEVER on an inertia based rolling road, we use a figure called the "simulated road load" which is based on the vehicles mass, and allows us to determine a correct flywheel mass moment of inertia and/or gearing for the flywheel to give a suitable "resistence" effect to perform an adequate acceleration run. This principal is similar to the performance analyser as discussed in this thread.
