Rear washer jet
Which route does the rear washer jet piping take?
Haven't looked at tracing it yet but want an idea of what to start pulling off to check for a blockage as mine doesn't seam to be working
It goes down the right hand side of the car (OS), through the interior. If you pull the trim off near the drivers feet you should see it, the pipe was see through on my car.
I've near heard of a blockage in the pipes before though, I would imagine more likely the washer motor is at fault.
i does take quite awhile for the water to quirt out, just incase you think its instant
Had similar problem when I had my 197, it was just trickling out. Took it back 4 times to the staelers who denied there was a problem untill I got them to compare it side by side with one on the forecourt. Turned out to be the wash pipe trapped underneath the washer bottle.:liambo:
Will have to investigate later when I get chance
Also look at front headlamp washer as that's not playing game!
Found the reason mine was not working . Picture from inside spoiler .
Put it on a dry drive/surface and run the washer for quite a while.
See if you have a wet patch.
My rear packed in and the pipe had come apart under the wheel arch lining and was pouring out from there.
It was a two min fix taking the liner partly off and putting the pipe back together.
