Rear Screen Washer - Non-return valve location
jenic
Does anyone know where the non return valve is on the rear washer pipe, is it part of the motor or in-line somewhere?
Mine isn't working, which means the time to feed water is a good few seconds.
Thanks!
check valves are normally near the bottle but if your not sure put one in near the rear high level brake light if the others are not working then that will.
Reactions: jenic
