Raptor6767
Gold Member
I hope that I could afford to try the R3 airbox once...
I have a V6 airbox and I love it. Much better than the stock >4500rpm...
i would say the angle at which the air is getting drawn into the airbox then throttle body would differ, as with the R3 box the pipe to the throttle is almost curling back on it self, whereas the airflow on the v6 airbox is more straight with and right angle bend.
I have CAF into v6 box. No real difference. The problem is the pipe from airbox to TB. I cant seem to get the angle right. Going to fab a hard pipe.
The clio generally lacks low end torque. All the mods I've done which ultimately mean getting more air into the engine, as just pushed the power further up the rev range which is not where the clio really needs it. This further exacerbated by the cams. Set up is ideal for track or fast open roads and funny enough motorway but not in real world. When in the power band, my car is stupidly fast but problem remains below 3-4k.
This airbox I recon will make that even worse and the clio will feel dead below 3-4k. V6 airbox is the best compromise IMO.
on another note, i think the best way for maxogen to work is across where the battery would sit as you would use (if fitted) less cold air feed (pipe) with less bends in compared to if it was fitted along the back of the battery, yes there would be less of a bend on the throttle body with the second way but across the battery would be alittle bit of compremise.
Price is good but that is for the fiberglass one, the one in the pictures is carbon/kevlar which is 539, which still ain't bad really.
Do you guys want me to post their reply on here when i get it .
I am off to holland in June for Dutch time attach might be able to pick a couple of these up if people interested
