ok to jailbreak your ipad you need to download a small jailbreak program for either windows or mac depending on your laptop/computer.
so if you have a windows machine download
The Windows Jailbreak or the
Mac jailbreak.
step 1: Back up your ipad with itunes
Step 2: Goto your downloaded, find the compressed file and extract all of the contents like you would with any standard zip file. Place the files on your desktop for easy and quick access.
Step 3: Using a standard 30-pin connector cable, connect the device to be jailbroken with your computer.
Step 4: Launch the Absinthe tool through the executable file which you downloaded in step 1. When launched, the program will show an initial interface that will have some text-based information on it, and a “Jailbreak” button.
Step 5: If the device is connected properly as per step 3 then the Jailbreak button should be available. Press the button to begin the jailbreak process.
The initial Absinthe tool for iOS 5.0.1 accompanied with it a new method for jailbreaking iOS devices, so with that in mind, don’t be alarmed if the device looks like if it is going through a restore process. The progress bar on the Absinthe GUI will provide user feedback, please don’t touch the device at this time.
Step 6: When the payload process is complete and you’re confronted with your device’s lock screen, the ever familiar Cydia icon will be present on the home screen. The device is now successfully jailbroken untethered and you can now install any extensions or packages via Cydia, provided that your device is supported by them.
Now opening cydia app for the first time
it will prepare the file system
it will then close again iirc
open it again if it does and it will ask for what control you want
User, Hacker or Developer
select user and then hit done (top right)
Cydia will then open and do an update check.
You have now jailbroken your ipad
:bounce1:
Now to add "Trial" apps (full apps that are termed trial) you need to add an app via cydia called Install0us.
to do this you need to add a "repo" which is a link to download links to other bits of software (packages).
so open cydia
click the sources tab at the bottom (ipad only has this, iphone has manage, then sources)
click edit (top right)
then add (top left)
in the address bar add
http://cydia.hackulo.us/
once the download is done click the sources tab and you will see the
Hackulo.us link
click the right arrow
scroll down to installous 5 and click it
click install (top right)
confirm
and it will install the Install0us app
Ok so now open Install0us
from the home page click settings (top right)
and make sure they are all set to on
Now click search
search an app (say angry birds seasons)
open the app link you wish to install by clicking on it
and then click download link
this displays where you can download the app from
they will be listed with a version number off the app with newest version at the top
click one
add the capture code
then follow the download instructions (this depends on where the app is download from but they are all similar)
once the download completes install0us will install the app.
*****WARNING***** If you install an app via install0us NEVER update it via itunes or
YOU WILL BE CHARGED FOR THE APP, simply update it via install0us when available, there is an update tab to check for updates.
NOTE****^^^^^^^^^^^^^^^^^^^^^^^^^
:thumbup:
Jailbreak how too video [note it says ipad 2,4 in not included but it is now]
[YOUTUBE]SvhBGhsQmfY[/YOUTUBE]
How too add install0us
[YOUTUBE]iV2f2goHuTw[/YOUTUBE]
How to install apps via Install0us
[YOUTUBE]m1rnog4bqLM[/YOUTUBE]
