Project CUP mkII
Looks fun. What's more fun to drive though ??
That is a tough one! This was my first experience of FWD on track and had lot more fun than I was expecting, but on the other hand think I will definitely miss a bit powerslides.
We've just booked Cadwell Park for 26th Sept and will be a full day in the Clio - M2 won't be coming so I'll have a better idea after then.
Reactions: RSRowe and Beany
If you watched my video following an Ariel Atom you'll know just how wound up I got and tried to reach for a horn that wasn't there. So that job jumped straight to the top of the list to wire in a horn push.
48629684808_c32e98a66e_b.jpgUntitled by Sam Ratcliffe, on Flickr
After removing the steering hub which apparently was a 182 item, I was not happy with how secure it was, shaft and splines are the same but wasn't keen on the lack of purchase it had so ordered a mk3 OEM item, we also didn't have self cancelling indicators so that fixes that issue too... and it looks better.
While I was in this area I also added a 10mm spacer to the steering wheel and lowered the steering column (what a pig of a job that was)
48630184997_e242c1e01f_b.jpgUntitled by Sam Ratcliffe, on Flickr
Few posts back I said that I actually preferred the rubber pedals over the metal... I have to retract that statement.
I'd learnt heal & toe on a BMW platform with a floor mounted throttle pedal, it became second nature in the end it was that easy but the same style could not be transferred to the clio set up, got the hang of it by the end of the day but it required more effort.
So I got some OMP aluminum covers, only trouble was they were completely flat and clio pedals are not. Had to spend a good half hour on one of the hottest days in a sweaty garage with a blow lamp.
Very pleased with the end result though, heal & toe is now a doddle
48630039946_0548db671b_b.jpgUntitled by Sam Ratcliffe, on Flickr
We also added a massive sun strip using dark smoked headlight tinting film, something I've always used as it tough, blocks the sun well and can still be seen through.
Lastly we put some black textured vinyl on the B pillar. Don't think any 197 cup came with it but it just looks better.
Thinking of adding a Whiteline rear anti roll bar before Cadwell Park too.
Can you expand on this a bit please. I think I might have the same issue on my 200. Took the wheel off to investigate the non-functioning horn (been butchered, needs new clockspring) but found that the boss only slides a few mm back onto the splines before bottoming out and also indicators don't cancel. Was this what you found?
Could be the same issue, get a picture of the inside of you boss and should be able to see if its suited to your car.
We done Cadwell Park last week, all went well, still trying to get use to the car and was our first time on the track too
48821020428_8f9f6fd2f6_b.jpgXSP_8139 by Javelin Trackdays, on Flickr
48820992273_eeac84c21c_b.jpgXSP_8466 by Javelin Trackdays, on Flickr
48821347826_d8030ebc39_b.jpgXSP_8561 by Javelin Trackdays, on Flickr
48820840618_54d769fcb4_b.jpgXSP_8594 by Javelin Trackdays, on Flickr
48821330891_66d8f1140d_b.jpgXSP_8975 by Javelin Trackdays, on Flickr
48821192941_fc2ab27e32_b.jpgXSP_8995 by Javelin Trackdays, on Flickr
48821375527_867ac8e26c_b.jpgXSP_9540 by Javelin Trackdays, on Flickr
48821217151_e18687c6db_b.jpgXSP_9573 by Javelin Trackdays, on Flickr
48820852028_05c5fa45a4_b.jpgXSP_9778 by Javelin Trackdays, on Flickr
48821361942_f3bbdd3299_b.jpgXSP_9825 by Javelin Trackdays, on Flickr
48820939238_5840c9398e_b.jpgXSP_9281 by Javelin Trackdays, on Flickr
Cheers, it really struggled in 5th going up the hill on Park straight, just need to carry more speed to slingshot down the straights.
It’s on Yoko AD08R, not an amazing tyre but is working well on this. Has no camber so the outer edges are bit dead. Adjustable mounts and shins are on the list... with a rear ARB too.
Reactions: Big Ben and Beany
Anything done with the gearbox ? Looked a nice clean lap
A Quaife ATB, which I was on the fence about as had a Wavetrac ATB in my m3 and it was the biggest pile of w@nk ever! But this is okay, guessing ATB work in FWD just not RWD.
Was on a slow lap on the run into that one as some lemon in a 172 kept on holding me up and wouldn’t move so held back to get some clear air.
Went well anyway it’s nice to see another video to compare against kind of how I went on..
Sadly most clios that venture out on track at same time are meg’d
We'd like to do a Donington day next so maybe could book on together.
We’ve booked on in 3rd November.. I appreciate it could be chilly, wet and windy!
But it’s a circuit not too far from me so would be up for that
Ah... I'm doing Silverstone GP in the M2 the day after, two track days on the trot in different cars will be pushing it I think haha.
Had Oulton Park this Saturday just gone, stayed wet all day with only bits of a dry line appearing just before the chequered flag dropped, times were starting to tumble though.
Definitely a circuit I'd love to go back to in the dry.
With both of us driving the car got very little rest and covered over 200 miles on track... hench why it got so dirty
49127018838_212244f29e_b.jpgOulton Park 23.11.19 - 0227 by Javelin Trackdays, on Flickr
49127512576_9f037f78d6_b.jpgOulton Park 23.11.19 - 0075 by Javelin Trackdays, on Flickr
49127016898_27d028cfb7_b.jpgOulton Park 23.11.19 - 0346 by Javelin Trackdays, on Flickr
49127501031_344427cf04_b.jpgOulton Park 23.11.19 - 0719 by Javelin Trackdays, on Flickr
49127000778_17a73c84ee_b.jpgOulton Park 23.11.19 - 1116 by Javelin Trackdays, on Flickr
49127511341_8450f1cf3a_b.jpgOulton Park 23.11.19 - 0139 by Javelin Trackdays, on Flickr
Haven't any other track days planned just yet as want to do a list of things to the car... top of that list is add camber, lack of it hasn't been a problem in the wet but is a major issue in the dry.
Nothing too exciting but a lap from Oulton... will be going through all my footage in the next few days and will stick some of the understeering - funny moments & exceeding track limits on my instagram.
