You need to take;
Kettle
Helmet
Tea Bags
Chocolate hobnobs
Cable Ties
Duct Tape
Foot Pump
Spare Underpants
Hat (to hide hair once the helmet is off)
Insurance is available from a few places, I favour Pace Ward. Some companies will only cover you for bodywork damage but they won't tell you this, it'll be in the small print. So you really need to do your homework on that one to save being caught out should the sh!t hit the fan. Beyond that, the usual pre-trip checks to tyres and fluid levels as well as getting a decent nights kip beforehand and that's pretty much it mate.
You need to take;
Kettle
Helmet
Tea Bags
Cable Ties
Duct Tape
Foot Pump
Spare Underpants
Ooooooh, almost forgot the most important one for you Litchy...
Make sure you arrive ON TIME!!!
You need to wear long sleeves to, although they were a bit slack a Bedford
Ill tell what I do before setting off.
Check all the wheels are torqued.
Check the level of the brake pads.
Usual oil, coolant, brake fluid level check.
You'll need an air pump or a gauge that'll let you adjust your tyre pressures. (nothing worse than mind numbing understeer because your tyres are too hot, that and itll ruin the middle of your tyres)
Everyones different regards tyre pressures but I start mine at 26 all round, take it easy for a 10 min session then adjust them to the factory Front: 33 Rear: 31.
Drink plenty of water or youll end up with a major headache
Dont forget your Licence either, nothing worse than that !
Also make sure you do a cool down lap where you hardly use the brakes, just pootle round letting everything have a bit of a rest instead of bareling into the pits and turning the car off.
Dont use the handbrake in the pits either the pads will bind to the disc, try and roll to a stop and leave the car in gear.
Oil Pump & Track Preparation | Engine, Gearbox, Exhaust and Air Intake | 3 | |
Red Motamec track prepped 197 Blyton Sat | Spotted | 1 | |
Trackday prep | Clio General Chat | 2 | |
T | Track day preparation | Suspension, Brakes & Steering | 12 | |
Clio Track Prep | Engine, Gearbox, Exhaust and Air Intake | 3 |
