Raptor6767
Gold Member
			Wanted to do something similar with my intake but haven't found the way to properly secure the coolant tank. Can you post some more pics of it?
Even if it's open all the time, I don't think it will make any issues in driving feel because (I think) it can't influence the performance.Hi Guys? I noticed my acoustic valve is open when the car is off? Should it not be closed?
Sent from my SM-G900F using Tapatalk
But does it work?
Tbh I've never looked into the standard breather setup, so hopefully this will be giving you a nice improvement.Acoustic valve doesnt open until 5(?)k. And when it does open its then forced to suck in warmish air as it sits fairly well in the middle of the bay.
This 'modded' feed is fed from a stream of cold air under the headlight and with acoustic valve binned - and is open all the time. So that alone makes everything extremely promising on paper.
My mapper never had any bad words about it, and this with a couple of other small mods showed a good increase when it was re-mapped for the second time.
**Although i never directly and scientifically compared this to the standard factory set-up.
Coupled with a map though - i cannot see how it can possibly be "worse" when all i'm doing is providing a better feed of colder air to the standard airbox set-up. (**Bar panel filter).
Were is that pipe from entering the airbox?, its got a much softer curve than the almost L elbows of norm?
Acoustic Valve removed.
New cold air feed; directed from down under headlight and fed straight into airbox via some silicone couplers and aluminium pipework. (Which is readily available on ebay)
Quick question as im confused yet again lol.
is this whole thing the acoustic valve? http://i82.photobucket.com/albums/j253/Clang182/Image0101.jpg
i've read all the acoustic valve threads (most of the images seem dead though). Im confused as some seem to just take this whole thing off and either route a new cold air feed to block some hose off? And others mention the acoustic valve being under the passenger wheel arch on the same bracket as the horn?
