This week .....I've mostly been fabricating!!
Although not brilliant, haven't welded for a good 8months and should of practiced before hand.
Tackled the throttle cable, mk1 design. Mk2 to come but does the job. Had to approach it this way to ensure nice smooth curves on the cable.
Found these a little while back, had to do some work on them and still more in the way of replacing the bushes.
Also test fit the android dash - using DTA S60 ecu with dtadriod app. Had some initial comms issues. As in baud rate on the rs232 to USB converter. Some duff USB leads!! But got there. Still playing around with the initial screen design but it's practical for now
In the process of fitting oil cooler and fabbing up a new alternator bracket. Tidied up the engine front, the sandwich plate is causing issues at the minute, trying to find a temperature sensor short enough to screw in the already ported plate.
It will be ready for Clio sport weekend [emoji53]
Your engine mounts are awesome!! I need that box mount!
_________________________________
GW 197 ex Michelin Road Cup Racer -> Track car/Sprints
http://www.clio197.net/threads/gw-197-ex-michelin-road-cup-racer-track-car-sprints.53560/
