Oil temp gauge
Hiya guys and girls newbie to the 200 world does anyone run a oil temp gauge?? I will.doing track days wanna keep eye on it I fitted one in my last car no problem not sure where to start on this many thanks jamie
I have this but haven’t fitted it yet.
I have one installed into my driver's side air vent:
The sender is taken off a thermostatic Mocal oil cooler plate:
I am told, by people with far more knowledge than me, that excess oil temps are not feature of the car and that even the race cars did not run an oil cooler.
Reactions: RSRowe
Although bear in mind that:
- Cup racers will be lighter than most road going Clios. Most Clios used on track will be road-biased therefore carrying a bit more weight with the engine working a bit harder as a consequence.
- Races are short compared to the length of time that you could be out on track, especially if doing lots of sessions without a great deal of time to let the car cool down.
- Oil temperature gauges are also useful not only from a high oil temperature perspective, but also a low oil temperature perspective. Keeping an eye on when the oil is adequately warm so that you can start to rev out the car is a useful touch, whether that be road driving or your first track session of the day when the car is cold.
If you get a thermostatic oil cooler then it will only open when needed to avoid over-cooling. Might not be a must-have, but it won't do any harm.
I was thinking the same the one got is mocal thermostatic one anyway 19 row oil cooler
I just wanted see people opinions and that
