My tpi bolts
Very noice. I assume you get supplied with the correct size socket to remove them? I'd think the standard 19mm wont work as they aint a hex head?
If you don't mind me asking what spec are these.
Tread, diameter, pitch and length. Also do Clio bolts have a taper on? I can't remember or check mine as I'm working say,regards joe
The clio bolts need to be M14x1.5 thread, and a 60 degree taper.
Not 100% on length so i'll leave that for someone else.
