TPI wheel bolts
Hi Noddie
If I’m not mistaken the correct size you need is M14 x 1.5 28mm Tapered
The seller you’ve linked is the distributor for Tpi - Send them a message and they should be able to get you them in the right size.
I did message them about some once and they were very helpful.
Checked some old threads I had saved in my bookmarks and positive I’m right with the size:
https://clio197.net/threads/wheel-bolts.57860/
They look fine though I've not yet put the new wheels on. Lockdown has meant I can't get tyres for them :chair:
I rate TPI wheel bolts, being using them for years with no issue. Recently considered moving to a wheel stud conversion though :sunglasses:
