updated.. been doing some things
I decided to bite the bullet a do a 63mm 3 box zhorst on the 200, I decided to leave the pre cat in, its not hollowed out yet. I know from the images that the centre box is a tad big, but at the time that’s the smallest the exhaust shop could find. Below are some attached photos, which I took with my crappy blackberry camera. All in all I can some up that, the 200s standard 60mm zhorst is very well designed and the only mod one could do to it is remove the huge back box and replace it with a twin back box setup and remove the cat after the pre cat.
this is what my car made in standard form before i did the exhaust system:
142kW
209Nm
at the flywheel
Exhaust system and single decat
then it was back to that very same dyno to see whether it made a difference,
she dynod in at
147kW
216Nm
at the fly wheel
then i did some cosmetic changes, i changed the front and rear diamonds and made them gloss black and some pics:
142kW
209Nm
at the flywheel
she dynod in at
147kW
216Nm
at the fly wheel
