A little late with the update as I was hopeful of having the track pictures but they've not landed yet...
Blyton Park // 08.04.2017
I booked an afternoon at Blyton with Mazda on Track to test the water with the Clio. The MoT days are well run and tend to have better than average driving etiquette.
One downside of the MoT days is that they tend to run the day in two halves, one on the Eastern Circuit and the other on the Outer Circuit. Happily in this instance they ran the Outer in the afternoon so I was able to have a later start than a typical trackday. I can't stand the Eastern Circuit, too much tight messing about at the start of the lap and then 'Curva Grande' that they sell as being a challenge to the car... the reality is just that the tarmac has sunk so it's bumpy and horrible!
The Outer Circuit on the other hand is very good for a flat, airfield type circuit, with a great variety of corners and an ideal proving ground for a new car or setup.
The plans to make the car useable on track had come together quite nicely, with all the 'must haves' covered, giving me confidence that it should be properly equipped for a reliable day's running.
The weather was absolutely splendid, sat at about 20* and bone dry. To be honest, it was warm enough that I was grateful that I wasn't in the sweaty, hot, noisebox that is the MX2000!! It wasn't hot enough to warrant AC though, precious couple of horsepower are better used going fast!
So, my first ever trackday in a front wheel drive car, let alone my first in this car. And right from the go in the afternoon session I left the pits following a well-prepared 197, best be on my A game!! I was quickly reminded to switch off the TC/stability by a bit of electronic interference on the way out of the first corner. Button duly pushed on the straight and the little car was simply terrific!
I expected it to be good for a road car but was amazed at just how easy it was to drive, by the end of the first lap I had the confidence to drive it hard. Without trying too hard I was able to hang on to the back of the track 197 and it was interesting to see a couple of areas where it (or the driver) was noticeably faster. In the sweeping exit from the first complex it would hook up a bit better and out of the slow chicane it was much better. I would be interested in finding out what has been done to the car beyond the well advertised Bilstein suspension and weight loss.
So a terrific first session following the 197 around and it just got better as the day went on. The CL brakes were mighty and I didn't have the problem with heel and toe that I had feared. The AD08r tyres did exactly what was expected of them, feeling like a 'quarter slick' in terms of outright grip and not giving up all day despite the abuse they suffered.
That fact that I don't have much to say about the suspension is a glowing endorsement, the sacrifice in road comfort delivering the promised dynamic reward and I wasn't left craving coilovers.
Coolant temp was rock solid at a little below the halfway point and it didn't use a drop of oil all day!
The seats were great for recliners, a little core strength was required in places and I would definitely benefit from fixed buckets and harnesses, but the ease of use of the normal seats and belts more than offset that on this car.
Although it's a fairly small car, it's not particularly light (I should think mine is >1250kg) and it doesn't trick you into thinking it is either. But equally it doesn't feel heavy and cumbersome on track and the quick rack makes it feel willing and eager, even if it doesn't dart around like a flyweight.
The chassis is very capable and grown up, dare I say even a little too grown up?... I tried playing around with tyre pressures to provoke a little more mobility at the rear but perhaps I wasn't aggressive enough with the changes.
I must have left my external gps switched on having been checking the accuracy of the speedo en route to the track, it seems I inadvertently logged a session on Harry's... 2up it did a 1:16.6 which is a little quicker than expected and more importantly, a few tenths quicker than a friend's similarly modified 350z at the same track! I reckon that's good going from the little Terrier!
So the first track outing, albeit just an afternoon was a huge success and hugely enjoyable! I have paid for a bundle of five trackdays with my insurance company so I'm going to have to use them all up!
The following day I gave the car a check over, swapped the wheels front to rear, swapped the CLs for some OEM Pagids for road use and put the compact subwoofer back in.
Will loves a pose!
The pads have barely worn which is good though I would have been very disappointed to find anything else having opted for the RC6s.
Interestingly, despite the warnings I've heard about the CLs being hugely dusty, there was barely any at all. Less than the Renault OEM pads at the back! I've also had very little squeal too, as longs as they don't go through discs too quickly with road use I don't see any reason that they couldn't be used all the time instead of swapping.
Very little dust:
Pad wear:
Labelled up for next time:
The tyres are mostly ok, however there is a band of heavier wear on the inside centre quarter of the outside front. Given that this was just an afternoon I'm a bit worried that I might get through these tyres a bit quick!
I will likely get a spare pair of wheels and fit some slightly more track orientated rubber for the front. I know a few chaps who run either narrower or less extreme tyres at the rear on FWD track/race cars without oversteer problems, and two of them are CRXs which are much more pointy than the 200.
If anyone has a spare pair of 200 wheels or can point me in the direction of someone selling it would be appreciated!
Sorry the first half was a text fest! Track pics to come and then a vid once I've edited it.
