Right, I got those suckers in last night, eventually!
It honestly took about four and a half hours, quite a bit of swearing and no shortage of percussive reasoning!
A note to
@Flacsi , instructions would make your product 100% better. I'm not a skilled mechanic but I have a number of track cars that I prepare and maintain so I'm not completely without competence.
Given the value of my Recaros i was worried about doing something wrong when disassembling them so having some guidance would be so reassuring and save an awful lot of 'figuring out' time!
The mounts seemed to go together when done in a certain order too, even then I had to use plenty of force. And it meant I had to undo and redo a number of steps. The fit wasn't perfect, but I didn't expect that from a low volume, sensibly priced part and the fact that I didn't have to modify anything is testament to a good degree of quality.
The seatbelt stalk but has a captive nut on the oem mount which isn't there on the new mounts. By chance I had a Honda gearknob nut that happened to be the right size otherwise I would be in a bit of a pickle with no driveable car and a trackday tomorrow. At close to zero cost a nut should be included with the kit.
So there are a number of ways the product could be improved, however it does exactly what it needs to.
Getting into the car is far, far easier, you don't have to go up and over the delicate bolster any more, you simply drop in which is great.
Once you're in, the seating position feels normal, which is fantastic given the abnormally high oem position. It really makes a nice difference.
One thing which is a big disappointment is the amount it lowers the seat by. The advert says 6-7cm but there's no way it's that much. See the pictures below but I think the reality is much closer to 2cm. This is really not fair when it promises so much more.
Putting this aside, the mount does enough to make it worthwhile. I would recommend them to anyone with Recaros, just keep in mind the smaller change and fitting might be a bit of a ball ache.
I should also commend
@Flacsi 's communication which has been excellent throughout.
As standard:
With the lowered mount:
I'm really thrilled with the car now and can't wait for Blyton on Saturday!
I'll be sure to get some video as always!
